Frigidaire Top Loader
Washer Is Not Doing Any Thing. There Is No Voltage Present At The Lid Switch,120v Are Coming In A Black Wire Coming From Power Cord And Going Into The Timer And 120v Are Present In A White Black Wire Coming Out Of The Timer, I Think Its A Bad Timer, Need Your Help Before I Buy A New Timer. Thanks In Advance
Without being there to troubleshoot the wiring with a meter we really can not do very much.
If you buy the timer from this site and it does not fix the problem you can return it under certain not very restrictive conditions. See the returns policy or talk with APP.
