Frigidaire upright freezer cycles from -2 to 35
Hello,
About 3 days ago I noticed the freezer was running at 25 degrees, after having been at -2 for as long as I can remember. I kept an eye on it and eventually it climbed to 40. I unplugged it to see if it would reset and it didn’t magically do so - but soon afterward it started going down again and reached back to -2. This lasted a day before it started climbing back up again.
At this point we emptied it and I checked continuity on the evaporator heater and it checked OK. I also tested the evaporator thermostat and it was also good - open at room temperature, closed after being in a (different) freezer, then I held it in my hand with the ohm meter and heard it click open after a few seconds and the ohm meter registered open again.
So its safe to say a lot of things are working, but not enough. No warranty and no help from the manufacturer. Just wonder if anyone has any ideas on what it might be and if it is worth it for me to try and repair. Thanks in advance.
MartyD
What is not running when it fails, compressor, evaporator fan, condensing fan, or all of the above?
