[SIZE=3]Hello! Currently have a Wall Oven (Frigidaire) that the door will not complety close. The events leading up to this are: the oven was in use, the power flickered a couple times real quick off and on. The board (clock) started flashing so pushed the cancel button and it stopped flashing. Upon trying to open the door it would not open so gave it a litte "tug" to open to remove the contents. It appears that the lock mechanism may have engaged, (not for sure what happened) but the locking pin or rod was sticking out about an inch and turned to the 3 o’clock position which is what appeared to be keeping the door closed. When tried to close the door the pin/rod would not allow the door to completly close. Therefore the oven door will only close as far as the pin/rod will allow it to close which is just barely short of making contact with the light switch that turns off the oven light. I have tried pushing the buttons one the panel but can’t get anyting to retract the pin/rod. If you can assit me I would greatly appreciate it.[/SIZE]
Related topics
Door Locked | 1 | 1038 | June 29, 2010 | |
oven locked dor open light flashing | 1 | 106 | January 3, 2012 | |
oven wont close | 4 | 1036 | March 17, 2011 | |
Oven door will not close | 1 | 1973 | November 1, 2009 | |
Door Won't Close Completely | 1 | 1079 | July 7, 2011 |
