I have a Frigidaire front loader model FWT645RHs0 that does not spin or agitate.
The shocks and one suspension spring had broke which I replaced. When I plugged it back in it will fill with water but
not agitate the tub or spin. There is a slight hum but nothing happens. The timer knob does not advance. If I rotate the
control knob to a point where the drain pump turns on it will drain but the pump does not seem to turn off.
Investigation:
I found what looked like the ground wire for the motor off. (Connects to the bracket rather than being part
of the bundle going in the motor.) I reconnected the wire but no change in behavior.
The voltage on the 5 & 6 pins on the 6 pin plug are good.
The voltage between the 5 pin of the 6 pin plug and the 2, 6 & 10 pins on the 10 pin plug are good.
The voltage between the 5 pin of the 6 pin plug and the 1 pin on the 10 pin plug should be 0 but is 30.
