My Frigidaire washer will not spin. It agitates. But won’t spin. I took the front cover panel off, and the belt is spinning on agitate, but not on spin. The belt is burnt also. The transmission was replaced 6 months ago. The seal is leaking under the agitater, leaking onto transmission from underneath on agitate and on spin cycle. I checked the motor to see if it was spinning and it is spinning on agitate with belt on, but I didn’t check with belt off, I assume that since the motor is spinning on agitate it should spin on the spin cycle to. Well, not sure if it is a bad motor, a relay, timer or what. The timer goes through all the cycles, but I guess that doesn’t mean it isn’t bad. Well, any help would be appreciated. Thanks!
Related topics
Frigidaire washer will agitate and drain but will not spin | 2 | 2616 | November 29, 2010 | |
Frigidaire washer agitating and draining but not spinning | 1 | 1815 | November 21, 2010 | |
HELP PLEASE!!! Frigidaire Washer will agitate and drain, but not spin | 2 | 2668 | November 29, 2010 | |
Frigidare washer won't spin | 1 | 2383 | October 23, 2007 | |
Frigidaire Washer won't spin | 2 | 2515 | November 22, 2009 |
