I have a problem with the water dispenser leaking when the dispenser lever is pushed. Water comes out the dispenser and also from another source above. It does not leak at other times. How do you gain access to the dispenser mechanism? Do you remove the ice funnel/ door? Does it just pop out?
I would appreciate your help.
Dan
