We recently took our dishwasher out to clean it out, and in the process of removing the hose from the drain pump, there is a rubber flap valve that has a hole on one side that slips over a notch in the pump outlet. I’m assuming that this lets water out, but prevents it from coming back down the drain hose and sitting in the bottom of the dishwasher. The part that slips over the notch tore and I have noticed water sitting in the very bottom of the tub. Where can I get a new flap valve? I’ve looked at all the diagrams and do not see it.
i had a broken lach assy and replaced it with a new one and know im not getting any power anyy sugg estions
It could be a door switch on the latch assembly is not closing.
