I have a frigidaire front loader and you shut the door the door lock is on and when you start the machine nothing works…plz help…and thank you
The door lock may be on, but the timer may not know that, so check the wiring in the door lock assembly and the wiring going to the timer.
Also, there should be some tech notes inside the lower service panel that will help you diagnose things.
