took front door panel off to replace heating element. Put everything back together but forgot what placement wires go back on switch
Getting wiring info on a GE is nearly impossible they like to keep this a secret.
Here are a couple wiring diagrams that may help.
I would check the wire’s path before hooking it up.
White usually goes to the Common
Normally Close to the interior lamp if you have one
Normally Open to the motor
http://www.applianceaid.com/image/geediagram.JPG
http://www.applianceaid.com/newimages/ge-newelec-diagram.JPG
