frost buildup in icemaker chute
About a year ago frost began to build up in ice dispenser chute in freezer door. It would get to the point that every 2-4 weeks I had to manually defrost the chute…dry it out …and wait again for it to recur…Suspect problem is in ice door flapper (your part # AP3672582). I printed diagram of freezer door from your website…is this a simple/difficult replacement??
I was wondering if you managed to get this fixed? i have the same issue and am looking for advice on how to fix it!
Having an issue replacing the access door any suggestions?
Thanks for the tip!
Will give this a try (gasket replacement), and if that doesn’t work, solenoid replacement.
Cheers!
:slight_smile:
Just finished this repair this weekend. Replaced the flapper valve, which was distorted and curled…which led to the frost buildup and clogging. I also replaced the solenoid which was super easy…not required but I bought the part anyway.
The tricky part is those three small holes that you use a tiny screwdriver to pry up and outward to help release the control panel. I took pics with my cellphone to make sue all wires went back properly.
Works like a charm…wish I’d done this two years ago! Lol.
Thanks for the tips.
