frozen control assembly
hello,
i have an old JennAir gas cooktop. i am buying new parts and also need to repair/rebuild one knob control assembly (left rear) i can not determine from the blow up of the knob control how many parts i actually need to buy/replace. i can not push down on the knob or turn it. also i need to replace the 2 ignightors, same problem, unable to determine which parts are re-useable which need replaced. any help would be very appreciated. thanks, Cinderella2, just a girl trying to fix her range. that’s my story and i am sticking to it.
Hi Cinderella2,
Looks like you have to replace the left rear gas valve. I did not get why you need to replace the igniters. What is wrong there?
In order to provide the right part number for the gas valve I need the serial number of the stove.
I would recommend to read the [B]service manual[/B] before you do anything. It will help you to figure out if you are able to handle such repairs.
Here are the break down diagrams for the Jenn Air cooktop http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=859957&&model_id=24091
Hi cinderella2,
Hi Ian,
Both gas valves have to be replaced.
I have a JennAir CG200B serial no 352264TR that I personally installed in 1984. I am experienced in repairing most appliances, but need the correct part number and instruction on how to replace the right rear burner gas controls as it is stuck in the off position. The left rear is is sticky, can it be serviced or does it need to be replaced too?
Can you please tell me what parts I need and give me a link to the service manual for this model?
thanks, Big Bob
Big Bob,
Gas burner valves are not serviceable, so both of them have to be replaced.
  • The right side gas burner valve [part]AP4088331[/part]
  • The left side gas burner valve [part]AP4088332[/part]
Here is the [Replacement parts for JENN-AIR CG200B Surface Unit - Ddraft Gas | AppliancePartsPros.com](http://servicematters.com/maytag_library/docs/16000443%20(gc001-00).pdf"]Service manual[/URL].
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=24138)
Thanks very much for the info Gene.
A little more info:
Are the valves that you gave numbers for the REAR valves, and are they different than the front ones ? (I need rears)
What is involved in removing the control console cover, does it pry off or are there fastners holding it?
Thanks again, Big Bob
Can you give me a link to the service manual for this model that tells how to replace the valve so I don’t attack the project the wrong way?
Thanks again,
Big Bob
The left side rear and front valves have the same part number. The same thing is about the right side valves. The link for the Service manual is in my previous reply!
