I replaced broken belt, tensioner, rear bearing assy and sliders, now when i turn the starter switch the dryer will not stay running, as long as I hold the switch to the right it will run and the gas will light up. When I let off the switch everything shuts off, i checked the door switch it’s working fine. this problem started after i replaced the parts, what could i have knocked loose? i looked for loose wires found none. please help. tks skonny.
Related topics
Dryer will not keep running after I let go of the starter switch | 2 | 1877 | April 19, 2011 | |
ge dryer won't run | 1 | 1159 | October 9, 2013 | |
Whirlpool Gas Dryer | 2 | 927 | January 30, 2010 | |
GE Dryer does not stay on | 1 | 2382 | November 17, 2011 | |
my GE dryer wont stay running it use to run as long as im holding the start but | 1 | 846 | March 11, 2014 |
