Just received a new oven control unit that does not exactly match my existing part. First of all…there is no ground lug installed on the new oven control (no terminal lug mounted on circuit board). Also the new unit has additional mounting lugs for the bake (2) and broil (3) componrnts than my original oven control, which has lugs designated E-8 and E-9 right on the circuit board. I need help…I’m not sure which lugs to use on the bake and broil components. I currently have the yellow wire connected to E-8 (bake) and the purple wire connected to E-9 (broil). I also have black wire connected to E-10 which is also jumpered over to
E-4 (also designated L1A). The new oven control unit is designated with tab numbers Tab-1, etc. and do not seem to match up directly. Please help! Thank you…
