Gas leaking around knobs
We had been smelling gas for a couple of days. The gas company checked our stove and found that the knobs on the front of the stove were in his words seeping gas. what do I need to replace? I didn’t want to buy a new stove.
Thanks:confused:
Remove all burners. Lift up the top panel and, using a soapy water, check all gas line connections and gas valves for a bubbles. Post the results.
Here are the break down diagrams for the Amana range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=711265&&model_id=18960
P.S. Do not forget to unplug the range first.
