gas oven problems
i have a gas range,when the oven is turned on it ignites, then heats to the required temperature ,then it normally cuts out .when the oven cuts back in to reheat to the required temperature i get a gurggling sound from the oven, even as the tube is lit .it sounds like when your barbecue blows out in the wind .i have installed a new igniter and have checked the brass jet for wear and dirt.the flame tube appears to be straight over the jet and all holes free of dirt. where should i turn next.
i have tried closing the air shutter and it makes no difference it still gurrgles with it opened or closed. your comments are appreciated!
Remove the burner and, using a toothpick, clean the hole in the orifice.
oven now works,we have used it twice and all seems fine .thanks you were agreat help.
I’m glad you were able to fix it.
