Gas oven temperature is inconsistent
Thanks in advance for your help…
99% of the time the oven heats properly, but occasionally it decides it won’t come up to the set temperature. Tonight I set the oven to preheat to 475 degrees. It did start to heat up but never came close to reaching the set temp. Tried turning it off and back on several times to no avail. Finally raised temp setting to 550 degrees and the temp FINALLY started coming up. At any temp setting I can see the glow in the bottom of the oven and it IS heating somewhat, but sometimes will not reach to set temp. How can it work most of the time, but not work at other times?
I’ve read on some forums that it might be the ignitor, but if I’m getting SOME heat, how can it be the ignitor?
Any ideas???
Thanks.
