Kenmore gas range oven will not come on ! The surface ignitor in the oven does glow,however no gas goes into oven.Now when I turn on the broiler the glow bare come on and gas is ignited.So the broiler is fine. Its the oven-when the oven is turned on only the glow bar is on–no gas ?? Thanks, Charles S/N # of range VF53620981
Hi.
Most likely it’s a bad ignitor, even if it’s glowing it may not "pull" 3.25 Amps in order to open the gas valve.
If you have the amp meter, check it.
The ignitor 316489401
Thank you. Post the results.
Simon.
