previous post had same problem, you suggested checking the lid switch.
I think the lid switch is magnetic, how do you check it or by pass it?
First make sure that the magnet is still attached to the lid.
You can check it by disconnecting it and then putting a magnet close to it.
It should switch from infinite to 0 ohms.
— Begin quote from rjb1939;664979
magnet switch is working.
when washer tries to go to spin nothing happens, but I can hear a low hum.
