My four year old free standing icemaker has stopped making ice! Water supply and fill work OK. The unit appears to be stuck in a clean or defrost cycle. I have nothing but the operator manual. I says clean the condensor which I have done. I have pretty good troubleshooting skills but don’t knoiw what to do next? Thanks in advance for your help.
If you find anything, please let me know. I am having the same problem. Thanks
My gardage disposal is jammed. I can move blades freely but it keeps making the humming noise. I alos cannot unjam it with te wrench. I tried pretty hard to unjam it but no luck.
Any idea?
Unplug the garbage disposer and using a flash light look inside through the top. Most likely there is a metal screw stuck or something similar to it.
I have a Maytag garbage disposal model #DFC3000AAX-1. It is whirling around but doesn’t sound like blades are going. I pulled out all debris with tongs. I also used the wrench both ways and hit reset button but nothing improved. Does this mean it needs to be replaced? Please send me suggestions. Thanks
Gene said:
Unplug the garbage disposer and using a flash light look inside through the top. Most likely there is a metal screw stuck or something similar to it.Gene.
Okay, I found out there is a screw stuck in my disposal, how do I remove it? I tried pulling it out with a needle nose pliers, but there isn’t enough room in there to really make sure it is in the right place. Should I remove the disposer?
If nothing else works then this probably the only solution.
