I checked the appliancepartspro.com site (and GE part site) to order parts needed to repair GE Model #JXDC41 (this model was replaced by JXDC41NBC). The repair requires parts #160 AP2021553 (Receptacle Assembly) and #170 AP2012323 (Lead Hi-temp); however, these parts are no longer available. Can you suggest other comparable parts that can be used? I also need to order part #180 AP2021559 (Terminal Block, plastic)
needed to repair GE Model JXDC41
That is the model number of just an element cartridge that fits into a range or cooktop. Is that what you’re trying to repair?
— Begin quote from ____
(this model was replaced by JXDC41NBC). The repair requires parts #160 AP2021553 (Receptacle Assembly) and #170 AP2012323 (Lead Hi-temp); however, these parts are no longer available. Can you suggest other comparable parts that can be used?[/QUOTE]
I’m sorry but I don’t know where you’re getting those numbers from. Please post the model number you’re using to look them up. There doesn’t appear to be any parts lists for either JXDC41 or JXDC41NBC element cartridges here.
