After power failure alarm wont go off and key pad is out.cheked your forum and found a similar problem but there was no solution. please if someone has figuered it out by now HELP! Thanks in advance. George
Hi George,
The problem can be a bad turbidity sensor (#321 at the [B]diagram[/B]) or a bad control board. There is a very small chance for the keypad to be bad as well.
You can check the turbidity sensor for continuity across the terminals 1 & 4. If there is no continuity then the sensor is bad. In such situation it’s time for a new dishwasher because this part is no longer available.
If the sensor is good, replace the control board.
The control board WD21X10187
The key pad WD34X10908
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-ge-pdw9880j00ss.html
