Water sometimes leaks from the bottom of the door during cycles ( sometimes it doesn’t ! ) I took off the door seal and cleaned it and replaced it, it was quite twisted on the 2 bottom corners the problem still exsists. question is too repair or buy new.
the part seems to be AP2038861 and is in stock, would that make the seal tight and leakproof, would I need any adhesive to fix it in place.
