GE Dishwasher not responding
I have a GE Dishwasher GSD5560 (GSD5560G00SS) that seems to have stopped working. I don’t know what is relavant so I’ll list everything I know…
All the button lights are off. Pushing the buttons does nothing (no lights or beeps). Pushing the start button quickly 3 times causes the door to release the soap dispenser cup (as it’s supposed to). The dishwasher beeps once when you open the door (as it’s supposed to). When you unplug the power then plug in again, the light next to the washing status light blinks 2 times and the door makes a noise for about 2 seconds (similar to the noise it makes when opening the soap cup). It does not beep when the door latch is moved from lock to unlock (It’s been broken so long, I don’t remember if it’s supposed to beep).
I opened the sequence switch and the motor and gears seem to be moving freely. The Control assembly was water stained and had several spots of corrosion on the electronic boards so I replaced it. There has been no improvement, it acts exactly the same as described above.
Any suggestions?
Rhubarb
