Water will not drain and I’m not sure what I should do. I would really appreciate any help you could give me with me. --Thanks
Replacement parts for GE GSD2000J01WW | AppliancePartsPros.com
I am assuming it washes OK
First remove the kick plate.
Is the pump running when it should be draining?
Is The solenoid (Wash/drain) pulling down when it should be draining?
Left hand side attached to the pump housing.
If yes then you probably have a blocked drain hose or house drain blockage.
Undo the drain hose at the sink, often stuff can collect where the hose fits over the drain fitting and cause a plug.
If OK. Try to drain it into a pail. Besure to hold the hose there firmly and put a rag/towel over the top of the pail or you will nhane water everywhere.
Here is a goods site for basic repair help
http://www.applianceaid.com/dishwash.html
