While removing the front panel to investigate a bad blower motor, the door switch came apart. I’ve ordered a new transistor for the motor, but I’m not sure how the switch contacts go back together. Anyone got a picture of the inside, or a diagram of it?
Thanks, Mitch.
GE does not make its tech data available, so I would suggest you call them and see if they will send you tech material since you own the machine.
