Have Ge gas dryer model number DVL223GB4WW and it will only stay lit for about a minute, then flame goes out and still tumbles, but no heat. Checked sensor and it is open, .3 ohm across wires, ignitor tests 63.5 ohm at about 70 degrees in home temp. Vaccuumed all vents and retried few times. Checked connectors and reconnected, still same thing. By schematic, control thermostat has 7k ohm resistance across pink/blue wire and continuity between all other pink/orange wires and high limit thermostat has continuity when dryers unplugged. Any ideas???
Related topics
GE gas dryer doesn't heat | 0 | 1601 | December 13, 2009 | |
GE gas dryer spins and blows but no heat | 1 | 1469 | July 19, 2012 | |
No Heat in Gas Dryer | 1 | 927 | August 31, 2010 | |
GE inlet control thermostat | 11 | 7922 | December 5, 2012 | |
GE gas dryer will not heat | 4 | 2723 | September 27, 2012 |
