GE dryer, sometimes it heats and sometimes it does not........
GE dryer will heat and dry laundry most of the time, then sonetimes run it through a cycle and laundry is still wet and it is not hot in the dryer. If I unplug the unit for a couple of minutes it then seems to work fine. I was unable to locate the tech. sheet to run a diagnostics. Any help greatly appreciated. Thank you.
Mike
