dryer will not heat in auto cycle but will heat in time cycle model ddg7180ral
It sounds like you might have a temperature selector switch problem is it does not heat at all in the timed dry cycle. Pull the panel, and see if there are not any burn’t wires. If you need the heat selector switch the part # is WE4X778. Let us know how it goes. Tom http://www.applianceeducator.com
It sounds like you might have a temperature selector switch problem is it does not heat at all in the timed dry cycle. Pull the panel, and see if there are not any burn’t wires. If you need the heat selector switch the part # is WE4X778. Let us know how it goes. Tom ApplianceEducator.com
