Hi after cleaning my range-top the rear 6" coil element stopped working. When I turned it on something arced; looking at it closely the terminal clip contacted the element and was spot welded to it.
I tried swapping a known good 6" element to that location, and it didn’t heat either. I then tried the bad element in another location and it didn’t heat.
My guess is that: the 6" element and the infinite switch are damaged? Possibly the terminal block.
The range is a GE Model JSS16OP1WH
I just want to confirm the specific parts; the infinite switch on my unit looks different from the listed one on the website.
Infinite switch AP2023855
6" surface element AP2634727
Terminal block kit AP2021472
Thanks!
