dryer works but has skweel and scatching sound, like drive or idle pully has caught something. my problem is how the dryer comes apart? the back and bottom is solid and the top is not popping off, Any help?
Open the door and remove the screws holding the top panel through the door frame. Lift up the top panel and remove the four screws (2 - on the top and 2 on the bottom) holding the front panel. Remove the rear access panel and remove the belt from the idler and motor pulleys.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=21355624&&model_id=208227
