GE Electric Range
Not using range the other day and the thing started beeping.Have error code F7 and flashing E6.Pressed clear and a few minutes later same thing.Turned off power for 20 minutes.When turned back on same thing.Exact model is not listed at appliance pro but a model near this one is listed and under fault code F7 is not listed?
From the digging that I have done, it points to the ERC control Board. The part # is WB27T10416. Tom
