GE F7 Error
I have a GE JTP56W0A2WW with an F7 error code. I’ve read numerous articles throughout the internet and have concluded through tests that the F7 error is because of a loose connection between the keypad’s "data cable" and the oven control unit.
I’ve tried to clean the data cable’s connectors and I’ve tried to crimp the pins on the control unit to make a tighter fit on the data cable. All to no avail.
So, I resigned to replacing the control unit however my model’s control unit is not the same as the JTP56WA2WW from a visual comparison.
Suggestions?
Thank you.
Gene
