GE Fan stays on
Whenever I use my microwave, the fan will not stop running after. Have to unplug and plug back in. Also, when you turn on the fan, low is high, high is low and off is high…again need to unplug. Seems to have started when I had the oven cleaning (micro is above the range) and the fan on the microwave was on. Thanks!
You need a new control board, you have a relay that is sticking.
O.K., I was looking and found a few different parts;
[[SIZE=1]1262973[/SIZE]](http://www..com/SSPartDetail.aspx?s=t-HVM154OLM1CS±%3d%3di1262465&PartID=1262465"][SIZE=1]1262465[/SIZE][/URL][SIZE=1] Control Panel[/SIZE]
[SIZE=1]1262466[/SIZE][SIZE=1] Control Panel[/SIZE]
[SIZE=1]1262471[/SIZE][SIZE=1] [/SIZE]Panel control
[URL="http://www.
.com/SSPartDetail.aspx?s=t-HVM154OLM1CS±%3d%3di1262973&PartID=1262973)[SIZE=1] [/SIZE]Smart board
Just wondering which one it is? Thanks!
