GE freezer temps up & down
We have a GSL25JPABS side by side fridge. Our only problem now is we found the ice cream soft. This was after my wife mentioned the fridge sounds different, like it’s running all the time and I found the coils pretty much completely clogged with dirt and dust, which I promptly cleaned out and it sounded more normal]. After that we noticed the ice cream soft. I got a temperature gage and found the temperature to range from +20 to -20 degrees F, hanging out a lot more around +10. I removed the back panel and inspected the coils in the freezer, with just some ice around a few lower turns which I melted away with water. Any help would be appreciated on what to check next, or what part to replace. I called about a defrost timer, and they said there isn’t one on this unit, that it’s controlled by the main mother board, which is like $135. I was amazed a few years ago when the water through the door froze up and the little heater I purchased and installed worked so well. Hope to get the same good help.
Thanks,:confused:
Dominic
