OK before I get yelled at I’m not sure the exact model number of the fridge off hand, but here’s what I can tell you.
The fridge is a regular 21cf freezer on top, fridge on bottom.
It is very plain. Only "extra" I seen was a water dispenser inside.
Now… The freezer gets cold. Brutal cold. So the compressor, defrost heater, bimetal defrost thermostat and defrost timer, I have checked, they all work properly. The evap fan works and it set where it’s supposed to be. The fridge thermostat controller works. I thought it might be iced over blockage I couldn’t see. So I took the doors off and let it sit for literally 2 weeks. I then pulled the compartment with the flap between the fridge and freezer completely off, and STILL no temp change in the fridge… Freezer kicks tail
Someone please help! It’s much appreciated
