ge fridge
condenser coils had alot of dirt on them cleaned off the ev coils where froozen thawed and when i pluged in began to freeze again also ice taste bad
I’ve removed the panel on the back. Tried vacuuming but almost impossible. Not very dirty, but want them cleaned before I install the new mother board.
I don’t have an air compressor, so can I safely use the canned air used for computer boards? Or is there something better I can purchase at Harbor Freight, etc?
If you have a shop vac you can reverse where you connect the hose so that it blows, otherwise the canned air will do in place of an air compressor.
