Ge front load washer no power even after reset attempts
We had a power outage when using the washer in the middle of the wash cycle. When power restored…washing will not power on. No lights or anything. Outlet was tested and has power.
Went through reset with machine with unplugging and replugging machine in. Still no power. Took off top lid of washing machine…to see if there is an inline fuse or reset do not see anything like that. What can i do to checj for further diagnosis? I read something on another forum and possibly a control board or inline power filter. Need some help.
Thanks Mark
Follow the power cord where it comes in to the board it connects to. Check for voltage there.
If you have voltage and the board seems dead disconnect the power and look for burnt traces, bulged capacitors, blown transformer, and blown fuses.
If you are not comfortable doing this, you should probably hire someone.
