GE Front Load Washer-Stopping Issue
My washer runs and stops at the last 30 minutes of the wash cycle and does not run after. The screen just shows "30 mins" and the "Pause" keeps blinking. I end up having to have to press the Start button in order for it to restart again.
Is there any way to reset or fix this?
Your expertise is much appreciated!!!
Two Suggestions
  1. Take off the bottom panel and completely clean out the drain/pump.
if this does not solve the problem,
  1. Inside the panel you should find some troubleshooting tech notes. Put the machine in diagnosis mode and run through the procedures to see if they will tell you anything.
Good luck.
