I went into service mode and read the error code of 46. I measured the resistance of the 3 motor wires and they are read about 6 ohms or so. I also checked that there is no resistance to ground. I them measure the motor sensor wires (2 yellow wires that are on the P9 connector). They are supposed to read 118 Ohms. They are open. I just want to confirm that this is indeed a bad motor. Do I have to measure the 120V at the inverter? Please confirm that it’s a bad motor sensor since the wires are open and not around 112 Ohms.
Thanks,
Tony
