Our GE front loader is stopping at random times during the cycle and the door is unlocking, sometimes it locks again, most the time not. I pulled the strainer under the lower front panel and it was empty, though it has been jammed full in the past, I also removed the pump, took it apart, removed the impeller and cleaned a bunch of lint out of it, and I made sure the discharge line was clear, put it back together and it’s still doing it. It ends up taking like an hour and a half to keep relocking it and get through a load, sometimes at the end the clothes are still wet
Where do I go from here? I don’t have a ton of money right now to start replacing random parts.
Thanks!
