Ge frontloader won't prewash or rinse
Our GE frontload washer will run a load of clothes okay until it gets to the rinse cycle. Then it just stops and the "start/pause" button blinks as if it had been pressed (it also will not run a pre-wash cycle). I’m currently just running a "speed wash" cycle with no extra detergent after the initial cycle shuts down to rinse out the clothes, but it’s only a temporary fix.
Appreciate any help we can get figuring out what is wrong and how to fix it. Do the symptoms readily point to somethings? Is there a diagnostic test we could run to get a better idea of the problem?
