GE gas Dryer Squeaking and now grinding
Ge Gas dryer model# DBXR463GD2WW squeaking while in use. Squeaking seems to increase with weight of load. Heard a grind along with squeaking on last load. Please advise
Hi.
Most likely you need to replace the rear bearing kit
WE25M40
Also check the front glide bearing pads, replace if needed.
The glides WE1M507
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5241255
Thank you. Post the results.
Simon.
