GE gas oven stopped igniting
Hi
I’m hoping someone can help me. I have a GE gas oven model number JGBS17PEK1WWthat has stopped working. It will not ignite, and there isn’t any gas comeing from the burner. just before it stopped working we were having trouble with the tempature always getting up to the setting we had it on. I’ve replaced the thermostat, and the oven safety valve, but this has not fixed the problem. Anyone have any advice or help?
The igniter is not doing anything. the link you gave helped alot. the igniter must be bad. I guess i’ll replace that next and see. thanks for the help.
It should be easy enough to check to see if the ignitor was responsible for certain rather than just guessing. As long as it wasn’t glowing at all, the ignitor would have to be electrically open (have no continuity) to be the cause which can be determined with a simple continuity test.
LINK > http://www.appliance411.com/links/jump.cgi?ID=817
LINK > http://www.appliance411.com/data.php?ap=AP2020569
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=GE+Range*The Appliance Information Site*
=D~~~~~~
thanks again the help
