GE GFW850SPN0RS
I’ve noticed the fabric softner dispenser is almost always either holding water or has not dispensed the softner after a full cycle. I recently used the laundry sanitizer product (much thinner liquid than softner) and it also remained in the cup after a full cycle and an additional rinse cycle. Sometimes if I shut the compartment door quickly or "slam" the washer door, I will notice it draining down. I routinely run cleaning cycles and I have removed the dispenser tray and cleaned it. Any other suggestions before I give up and get a Donny ball?
*majority of time I am running delicate cycles with tap cold setting
TIA!
