Hi guys,
Our GE side by side fridge is not cooling after a power outage. The dispenser display is out with the board speaker making clicking noise however the fridge light inside turns on when opening the door. I have turned off the circuit breaker for 10 minutes and and waited and turned back on with no luck. Unplugged the fridge for 1/2 hour and plugged back again and still no luck. Have checked the mother board (200D6221G010) in the back and the control board for the dispenser (200D7355G003) and have not seen anything burned or any bloating capacitors. Any Ideas what could be causing this issue? In the past, after a few hours the fridge would automatically reset and compressor would kick in but its been a day now and still no luck.
PS. I have replaced the mentioned boards many times in the past but still get the same issue after a power outage.
Thanks,
Shawn
