I have a GE fridge. The icemaker quit working. I jump started the ice maker and it would cycle but no water would fill the tray. I changed the water valve and jump started the icemaker and water filled the tray. The problem is the icemaker hasn’t cycled by itself again to fill the tray with water a second time. Do I need to replace the icemaker, or is there something I am overlooking?
Hi.
Most likely you need a new icemaker.
The icemaker kit AP2718821
Thank you. Post the results.
Simon.
