GE JVM1860 PCB Buzzing Relay?
We started getting a "buzz" from the GE JVM1860 Microwave last night. The noise seems to come from the "o-lamp" relay on the WB27X10438 printed circuit board. That is the 4th from the bottom end of the line of 5 relays. It seems to be labeled "FT F3AA024E"
Does anyone know if that relay might be individually replaceable? Or anyone that might be able to do it?
Thanks, Ron
When the dish washer is filling and running, I hear a noise like a screw rattling around. I can’t place the noise in the motor on the bottom or the inlet valve for the water supply. Is it ok to spray wd 40 on the propeller that spins to see if this quiets the noise? or Do you think the rattling noise can be from the intake valve. I think replacing the intake valve is less costly and would be willing to try this before having a pro come in. Sorry for the long post, but I would like to fix this myself.
Thanks, Bill
were you ever successful in replacing this relay? I have the same problem.
— Begin quote from rpushee;6849
Thanks, Ron
I’m having this same issue. I would replace the board but it costs almost $200 and not worth putting into an old micro. Any suggestions?
Thanks,
P.J.
