GE JVM1870 Key Panel
I found this forum really helpful. So wen I hit a problem I thought I would check with this community as it has been most likely been solved before,
Yes the infamous -F3- problem is back.
My question is:
I noticed when looking for replacement keypad’s "Key Panel" (item # 10" in GE database for this model), there are three distinct part numbers listed.
PS753840/41/42
In an earlier post I had seen a expert provide a PDF guidance on how to replace the key pad. There, there was a mention of two variants of the Keypad part. However, that was for a different microwave or a different model.
My question is does anyone have any idea how to determine the right part number, before I spend $80 on ordering the wrong one. I am hoping there is a number on the original when I pull it apart(fingers crossed)
Any help would be appreciated.
— Begin quote from ppgopete;367866
My question is:
PS753840/41/42
In most cases, consecutive part numbers designate a color :
(example ) ps753840 may be white and the 41 may be a black, etc.
Supply us with a complete model number and we’ll be happy to advise you of the part needed.
Actual Microwave model is JVM1870SF03 spacemaker under the hood model
The keypad is black background with white text
:slight_smile:
— Begin quote from ppgopete;368686
:slight_smile:
Apparently we’re using different parts screens ?
The part number needed per the GE parts diagram and the model number you supplied,
You need MPN no. WB07X10629
AppliancePartsPros part no.
[part]AP3418746[/part]
Aah! I see why the part numbers are different, you are referring to the entire assembly. I was referring to only the membrane key panel
retails aroun $70 while the assembly is closer to $150
Do you have a separate kepad or keypanel membrane available in ApplianceParts?
I am talking about item 10 in the attached parts diagram.
Thanks for all the help
— Begin quote from ppgopete;369585
Sorry, But we don’t have a part number for the touchpad panel as an individual part number, in any of our parts resource screens,
I have a feeling, if you order the pad assembly alone, it may substitute over to the complete assembly, (the part I listed) ?
Good Luck
