I have a GE side by side refrigerator model number [COLOR=black][FONT=arial,helvetica,sans-serif]GSHF5PGXAE and the light switch at the bottom of the fresh food section had broken so the light will no longer turn off (the plastic switch took a direct hit from a jar and broke). I have found the replacement part WR23X10530 and have it on order. To remove the current switch, is it as easy as popping it straight out with a flat blade or is there more to it? Thanks for any help.
[/FONT][/COLOR]
