How To Replace The Light Bulb In Micro Oven. Do I Just Take The Outer Cover Off And The Bulb Plugs In And Is It Easy To Get To The Bulb Socket.
Yes, just remove the outer case and you’ll see how to handle it.
- The part number for the light bulb is AP2030108
Here is the break down diagram for the GE microwave http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=563434&&model_id=212982
